The ability to add scheduled downtime via the API is limited to full admin accounts
But normal non-admin users have the ability to set downtime via the front end
Can we get the permissions changed on this function in the API?
I frequently have to grant access to 3rd parties to allow them to programmatically downtime their services and the only way I can do this is to give them full admin access
Admin permissions needed for API downtime
optionstechnology
Re: Admin permissions needed for API downtime
Hello @optionstechnology
Thanks for reaching out on sending downtime via API.
I ran the test command to schedule downtime via API using two 'admin users' using API keys associated and find that the command successfully completed in both cases.
That leads me to my next question, what Nagios XI version are you on?
Also, what do you see for "authorizated_for_configuration_information" in cgi.cfg?
Perry
curl -XPOST "https://xxx.xxx.xxx.xxx/nagiosxi/api/v1/system/scheduleddowntime?apikey=AEiMFttHuQRqWEDbqgXYelB6GPCakE3F7i6CKQsNIMoAS9Pcol3eE3Ohe5fjYUGH&pretty=1" -d "comment=Test downtime creation&start=1631647944&end=1631655144&hosts[]=localhost" -k
"success": "Schedule downtime command(s) sent successfully.",
"scheduled": {
"hosts": [
"localhost"
[root@localhost ~]# curl -XPOST "https://xxx.xxx.xxx.xxx/nagiosxi/api/v1/system/scheduleddowntime?apikey=iIIcpAegUHQqa0QqOKk9Cn8LXPE7rDEEANWriIscHnVUFVe3S4Z38bE5Y7FJE8rL&pretty=1" -d "comment=Test downtime creation&start=1631647944&end=1631655144&hosts[]=localhost" -k
"scheduled": {
"hosts": [
"localhost"
grep -Eir 'authorized_for_configuration_information' /usr/local/nagiosxi/nom/checkpoints/nagioscore/*/cgi.cfg- I see listed: =nagiosadmin,nagiosadmin,myaliasid
Perry
