I am having problems with my Log Server, it is an old version 1.4.4. I am unable to apply the configurations via UI. I receive the following message:
192.168.102.4 (logserver) The instance is likely offline, please check and try again.
It looks like this instance hasn't checked in the last 5 minutes.
Normally this means it is not online or elasticsearch is not running.
If you don't know why it's offline, try these:
Verify that elasticsearch is running on the instance and start elasticsearch if necessary
Check the connection (firewall, cable link) to the instance from this instance
Wait for the instance to return to an online state and check in
I dont know what else to do.
