Hi All
we are using the below script, and some degraded fans keep alerting but the temperate is fine
Is there any way to ignore some of the fans or all if the fans, as the temperate is already monitored
https://exchange.nagios.org/directory/P ... th/details
Thank you
Fan degraded ILO health
Re: Fan degraded ILO health
Hi
This plugin is provided by a member of the community so you should talk to the author.
It looks like someone else is wanting the same functionality as you: Another option is if you know Perl you could take the plugin and modify it yourself.
And a third option is to create a script that executes the plugin, and then parses it's output before passing
it on to the Nagios XI server.
