I don't think my event que is working right:
Im running xi 5.8.6
how can I test this?event que question.
event que question.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: envent que question.
all set you can lock it up!
Thanks Tgriep!
solved it:
Thanks Tgriep!
solved it:
/usr/local/nagiosxi/tools/mysql_tune.sh
Edit /etc/my.cnf
Under the [mysqld] section add the following setting:
max_connections = 1000
open_files_limit = 4096
Save the file and restart Mariadb by running the following.
service mariadb restart
Proudly running:
Nagios Fusion
Nagios Fusion
Re: event que question.
Thanks Ben! We'll lock this one up.all set you can lock it up!
Thanks Tgriep!
