Hello everyone,
I would like to know if there is a way to create adaptive thresholds in Nagios for monitoring according to the time of the day. For example I want to have a different thresholds during the day and during the night. I know one solution can probably be to create separate config files and rotate them on a schedule, but this is not ideal. Are there any recommendations? Thanks in advance.
Dynamic threshold according to time
benjaminsmith
Re: Dynamic threshold according to time
That would be the easiest way to do it. It's not something built into XI or Core.
You could write a wrapper script for the plugin, and pass different thresholds depending on the time.
--Benjamin
--Benjamin
