Hi
Please
Do you know
API syntax to get service_description values as CMD
Thsk
Fer
FCC_Nagios_Support
FCC_Nagios_Support
Re: API syntax to get service_description values as CMD
We are under support
What is the URL to open a ticket
Many Thanks in Advance
KR
KR
benjaminsmith
If you'd like to open a ticket, please go to:
https://support.nagios.com/tickets/
If you're looking to pull service descriptions via the API, you can retrieve those using the GET config/service or GET objects/servicestatus endpoint. You'll find example commands in the documentation at Help > API Docs.
--Benjamin
--Benjamin
