Naming of auto configured Unconfigured Objects
nevillestyles
Post by nevillestyles »
Good afternoon,
We have enabled the Auto Configure settings for Unconfigured Objects:
We've done this so that new services are created should we receive SNMP traps from a new device, or if we receive an SNMP trap with a new service name (see https://support.nagios.com/forum/viewto ... 16&t=63240)
When a new service is created using this method, the name of the host it is associated with is set to its IP address:
Is there a way to change the auto configuration of the Unconfigured Objects so that new hosts are created with their DNS names (or names resolved from the local hosts file)?
Regards,
Neville
ssax
Dreams In Code
Re: Naming of auto configured Unconfigured Objects
Post by ssax »
It should do it by default, check this setting in /etc/snmp/snmptt.ini:
dns_enable = 1
Does nslookup work from the XI system that?
nslookup 10.29.74.76
Please run this command as root and attach (or PM) the resulting /tmp/SNMPFILES.tar.gz file:
tar czvf /tmp/SNMPFILES.tar.gz /etc/snmp
nevillestyles
Thanks for the response.
I can confirm dns_enable is set to 1.
nslookup returns a result, plus the host is in /etc/hosts:
$ nslookup 10.29.74.76
76.74.29.10.in-addr.arpa        name = pcen-td-01.<redacted>.
$ grep 10.29.74.76 /etc/hosts
10.29.74.76     pcen-TD-01
I'll PM you the file requested in the next few minutes.
Many thanks,
Neville
ssax
Dreams In Code
Post by ssax »
Looking at your traps defined in Admin > SNMP Trap Interface > Defined Traps I see most are using the Host Name settings of $aR which is:
$aR, $ar - IP address
Edit one of the traps and change it to use $r for the Host Name settings, then send a test trap and see if it shows up in Admin > Unconfigured Objects with the DNS name now.
Taken from here:
http://www.snmptt.org/docs/snmptt.shtml ... ONF-FORMAT
nevillestyles
Thank you very much, that worked perfectly. I'm not sure how I missed that!
