performance grapher not running
Markq
Post by Markq »
Hi, I try to start the performance grapher on the web gui, but received an error. Can I try something else?
thanks,
Mark
Re: performance grapher not running
From the console try
service npcd start
osbormd
Post by osbormd »
I had the same issue.
NPCD wouldn't start back up with the web gui, but service npcd start worked.
Is there a way to have Nagios check this service and start it automatically if it's stopped?
Thank you
Post by slansing »
Well, you should be able to restart it through the web interface, are you able to do that again now? If you wanted to, you could set up a check against that service, and then use an event handler to automatically start it if it stops.
osbormd
Post by osbormd »
Thank you! I will test this out.
Mike
Sure, let us know how it went.
