I have noticed, at times when I apply configuration either from the config wizard or configuration manager Nagios daemon is not running as the system health status reports it cannot find 'nagios.lock' under the XI System Component Status. I am having to manually start the daemon each time, and when I add new services, I have to manually reload the config "/etc/init.d/nagios reload". There is a lag between applying config and webpage refreshing. I have cleared local cache, and tried different browsers, issue still persists.
Is this a known issue?
Nagios deamon
ldcsupport
ldcsupport
Re: Nagios deamon
I am getting the following:
for services configured through configuration manager.
I am running NagiosXI 3.2.
You are not authorized to access this feature. Contact your Nagios XI administrator for more information, or to obtain access to this feature.I am running NagiosXI 3.2.
Re: Nagios deamon
When you finish a wizard or Apply configuration, this is normal behavior for the Nagios service to show down temporarily however it should start itself back up in a few moments if left alone.
