Passive check result | But host not found
lanxessinfy
Post by lanxessinfy »
Hi Team,
In our event log we found that
External command [1632808419] PROCESS_SERVICE_CHECK_RESULT;x.x.x.x;SNMP Traps;0;An authenticationFailure trap signifies that the SNMP 100.81.43.21 1 100.81.43.21 / enterprises.9.2.1.5.0 ():100.81.43.21 enterprises.9.9.412.1.1.1.0 ():1 enterprises.9.9.412.1.1.2.0 ():100.81.43.21 returned error Command failed
Error: External command failed -> PROCESS_SERVICE_CHECK_RESULT;x.x.x.x;SNMP Traps;0;An authenticationFailure trap signifies that the SNMP 100.81.43.21 1 100.81.43.21 / enterprises.9.2.1.5.0 ():100.81.43.21 enterprises.9.9.412.1.1.1.0 ():1 enterprises.9.9.412.1.1.2.0 ():100.81.43.21
Warning: Passive check result was received for service 'SNMP Traps' on host 'x.x.x.x', but the host could not be found!
That host is not configured in nagios.
How can we stop these checks?
Thanks!
pbroste
Re: Passive check result | But host not found
Post by pbroste »
Hello @lanxessinfy
That appears to be Auto populating from 'Unconfigured Objects'.
You can disable that from the Nagios XI Web console > Admin > Unconfigured Objects:
  • [ ] Enable Auto Import: Automatically import host/services into the CCM with templates applied below.
Please let us know if you need anything further,
Perry
lanxessinfy
I don't want to configure that host and how to stop those alerts
pbroste
Post by pbroste »
Hello @lanxessinfy
In my original reply; I made mention 'Unconfigured Objects' and want to check to see if the following is enabled?
If this option is enabled, the 'Unconfigured Objects will be automatically imported.
Please let me know what you find,
Perry
lanxessinfy
PFA
pbroste
Post by pbroste »
The host '10.249.119.4' will sit in the 'Unconfigured Objects List' until it is cleared and will not affect any future alerts.
Thanks, I will go ahead and lock.
Perry
