NagiosXI service (Monitoring Engine) is getting down
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
We could see the NagiosXI service is going into down state in frequently, we took restart of the NagiosXI server as well but this did not helped. We are currently using Nagios XI 5.8.3 version.
Redirecting to /bin/systemctl status nagios.service
● nagios.service - Nagios Core 4.4.6
Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; vendor preset: disabled)
Active: failed (Result: signal) since Mon 2021-10-04 10:27:08 BST; 2min 2s ago
Docs: https://www.nagios.org/documentation
Process: 9006 ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
Process: 23425 ExecStop=/bin/kill -s TERM ${MAINPID} (code=exited, status=0/SUCCESS)
Process: 5152 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Process: 5149 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Main PID: 5153 (code=killed, signal=KILL)
Oct 04 10:24:13 eu1papu003 nagios[5149]: Checking global event handlers...
Oct 04 10:24:13 eu1papu003 nagios[5149]: Checking obsessive compulsive processor commands...
Oct 04 10:24:13 eu1papu003 nagios[5149]: Checking misc settings...
Oct 04 10:24:13 eu1papu003 nagios[5149]: Total Warnings: 51
Oct 04 10:24:13 eu1papu003 nagios[5149]: Total Errors: 0
Oct 04 10:24:13 eu1papu003 nagios[5149]: Things look okay - No serious problems were detected during the pre-flight check
Oct 04 10:24:13 eu1papu003 systemd[1]: Started Nagios Core 4.4.6.
Oct 04 10:27:07 eu1papu003 systemd[1]: nagios.service: main process exited, code=killed, status=9/KILL
Oct 04 10:27:08 eu1papu003 systemd[1]: Unit nagios.service entered failed state.
Oct 04 10:27:08 eu1papu003 systemd[1]: nagios.service failed.
Could you please help us with corrective steps to fix this issue asap. Attaching profile as well for further investigation.
Your quick response is appreciated.
Nitin Parate
Thanks & Regards,
I2MP Team.
gsmith
Re: NagiosXI service (Monitoring Engine) is getting down
Post by gsmith »
Is this a duplicate of https://support.nagios.com/forum/viewto ... 16&t=63656 ?
If so may I close this one?
RIDS_I2MP
Post by RIDS_I2MP »
Yes, this can be closed.
Nitin Parate
Thanks & Regards,
I2MP Team.
