api cant add a new contactgroup
I'm trying to add contactgroups using the API, but it doesn't seem to be working :
The following command were gathered from the help page http://127.0.0.1/nagiosxi/help/
curl -XPOST "http://127.0.0.1/nagiosxi/api/v1/config ... N&pretty=1" -d "contactgroup_name=testcontactgroup&alias=newcontactgroup&applyconfig=1"
"success": "Added testcontactgroup to the system. Config applied, Nagios Core was restarted."
curl -XGET "http://127.0.0.1/nagiosxi/api/v1/config ... ntactgroup"
What am I doing wrong ?
we are using nagiosxi-5.8.6 on centos 7.9
Re: api cant add a new contactgroup
Hello @sigmainformatique
Thanks for reaching out; appears from the details that you provided that the POST was a success and applied. Since GET is blank when specifying the contactgroup name, want the command to get the list:
Please PM your updated system profile for us to review.
To send us your system profile.
Perry
curl -XGET "http://127.0.0.1/nagiosxi/api/v1/config/contactgroup?apikey=TOKEN&pretty=1&contactgroup_name" -v
- Login to the Nagios XI GUI using a web browser.
- Click the "Admin" > "System Profile" Menu
- Click the "Download Profile" button
- Save the profile.zip file and send via Private Message
Perry
- Listing all groups with curl or through web interface does not show the contactgroup "testcontactgroup".
- Download profile fails:
I can see errors in /var/log/httpd/error_log file :
The user "apache" is not allow to run any command using sudo.
PROFILE BUILD FAILED
Array
CODE: 1
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
sudo: no tty present and no askpass program specified
I have the same issue if I try to add a contact :
But the GET API does work :
curl -XGET "http://127.0.0.1/na[code]giosxi/api/v1/ ... agiosadmin"
"contact_name": "nagiosadmin",
"alias": "Nagios Admin",
][/code]
And so does the PUT calls :
curl -XPOST "http://127.0.0.1/nagiosxi/api/v1/config/contact?apikey=TOKEN&pretty=1" -d "contact_name=testcontact&host_notifications_enabled=1&service_notifications_enabled=1&host_notification_period=24x7&service_notification_period=24x7&host_notification_options=d,r&service_notification_options=w,c,r&host_notification_commands=notify-host-by-email&service_notification_commands=notify-service-by-email&applyconfig=1"
"success": "Added testcontact to the system. Config applied, Nagios Core was restarted."
curl -XGET "http://127.0.0.1/nagiosxi/api/v1/config/contact?apikey=TOKEN&pretty=1&contact_name=testcontact"
][/code]
curl -XPUT "http://127.0.0.1/nagiosxi/api/v1/config/contacgroup/rrrrrr/?apikey=token&members=msimon&applyconfig=1"
{"success":"Updated rrrrrr in the system. Config applied, Nagios Core was restarted."}
curl "http://127.0.0.1//nagiosxi/api/v1/config/contacgroupt?apikey=token=rrrrrr"
[{"contactgroup_name":"rrrrrr","alias":"rrrrrr","members":["msimon"]}]
curl -XPUT "http://127.0.0.1/nagiosxi/api/v1/config/contactgroup/rrrrrr/?apikey=token&members=msimon,nagiosadmin&applyconfig=1"
curl "http://127.0.0.1/nagiosxi/api/v1/config/contactgroup?apikey=token&contactgroup_name=rrrrrr"
[{"contactgroup_name":"rrrrrr","alias":"rrrrrr","members":["msimon","nagiosadmin"]}]
Thanks for following up with the details; appears that the user apache does not have enough permissions to run the System Profile script. Please run as root and then send vi Private Message:
Then send the resulting /usr/local/nagiosxi/var/components/profile.zip file via Private Message.
Perry
su -l root
rm -rf /usr/local/nagiosxi/var/components/profile.zip
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORT
Perry
I had to patch getprofile.sh to get it working :
--- getprofile.sh.org 2021-10-08 10:20:08.836068760 +0200
+++ getprofile.sh 2021-10-08 10:42:20.244000000 +0200
@@ -47,9 +47,10 @@
ver="${version%%.*}"
# Make a clean folder (but save profile.html)
-rm -rf "/usr/local/nagiosxi/var/components/profile/$folder/"
+[ -d "/usr/local/nagiosxi/var/components/profile/$folder/" ] && rm -rf "/usr/local/nagiosxi/var/components/profile/$folder/"
+[ -f "/usr/local/nagiosxi/var/components/profile/$folder/" ] && rm -f "/usr/local/nagiosxi/var/components/profile/$folder.zip"
+[ -f "/usr/local/nagiosxi/tmp/profile-$folder.html" ] && mv -f "/usr/local/nagiosxi/tmp/profile-$folder.html" "/usr/local/nagiosxi/var/components/profile/$folder/profile.html"
mkdir "/usr/local/nagiosxi/var/components/profile/$folder/"
-mv -f "/usr/local/nagiosxi/tmp/profile-$folder.html" "/usr/local/nagiosxi/var/components/profile/$folder/profile.html"
# Create the folder setup
mkdir -p "/usr/local/nagiosxi/var/components/profile/$folder/nagios-logs"
@@ -132,7 +133,34 @@
php -r '
define("CFG_ONLY", 1);
require_once($argv[1]);
- print(@$cfg["db_info"]["ndoutils"]["dbserver"] . "\n");
+ print(@$cfg["db_info"]["nagiosxi"]["dbserver"] . "\n");
+ '/usr/local/nagiosxi/html/config.inc.php' 2>/dev/null |
+ tail -1
+db_user=$(
+ php -r '
+ define("CFG_ONLY", 1);
+ require_once($argv[1]);
+ print(@$cfg["db_info"]["nagiosxi"]["user"] . "\n");
+ tail -1
+db_pwd=$(
+ php -r '
+ print(@$cfg["db_info"]["nagiosxi"]["pwd"] . "\n");
+ tail -1
+db_db=$(
+ php -r '
+ print(@$cfg["db_info"]["nagiosxi"]["db"] . "\n");
tail -1
@@ -168,21 +196,21 @@
else
echo "Getting xi_users..."
- echo 'select * from xi_users;' | mysql -u root -pnagiosxi nagiosxi -t > "/usr/local/nagiosxi/var/components/profile/$folder/xi_users.txt"
+ echo 'select * from xi_users;' | mysql -u ${db_user} -p"${db_pass}" ${db_db} -t > "/usr/local/nagiosxi/var/components/profile/$folder/xi_users.txt"
echo "Getting xi_usermeta..."
- echo 'select * from xi_usermeta;' | mysql -u root -pnagiosxi nagiosxi -t > "/usr/local/nagiosxi/var/components/profile/$folder/xi_usermeta.txt"
+ echo 'select * from xi_usermeta;' | mysql -u ${db_user} -p"${db_pass}" ${db_db} -t > "/usr/local/nagiosxi/var/components/profile/$folder/xi_usermeta.txt"
echo "Getting xi_options(mail)..."
- echo 'select * from xi_options;' | mysql -t -u root -pnagiosxi nagiosxi | grep mail > "/usr/local/nagiosxi/var/components/profile/$folder/xi_options_mail.txt"
+ echo 'select * from xi_options;' | mysql -t -u ${db_user} -p"${db_pass}" ${db_db} | grep mail > "/usr/local/nagiosxi/var/components/profile/$folder/xi_options_mail.txt"
echo "Getting xi_otions(smtp)..."
- echo 'select * from xi_options;' | mysql -t -u root -pnagiosxi nagiosxi | grep smtp > "/usr/local/nagiosxi/var/components/profile/$folder/xi_options_smtp.txt"
+ echo 'select * from xi_options;' | mysql -t -u ${db_user} -p"${db_pass}" ${db_db} | grep smtp > "/usr/local/nagiosxi/var/components/profile/$folder/xi_options_smtp.txt"
fi
if which mysqladmin >/dev/null 2>&1; then
- errlog=$(mysqladmin -u root -pnagiosxi variables | grep log_error)
+ errlog=$(mysqladmin -u ${db_user} -p"${db_pass}" variables | grep log_error)
if [ $? -eq 0 ] && [ -f "$errlog" ]; then
/usr/bin/tail -n500 "$errlog" > "/usr/local/nagiosxi/var/components/profile/$folder/logs/database_errors.txt"
fi
@@ -234,12 +262,12 @@
spool_perfdata_location=$(cat /usr/local/nagios/etc/pnp/npcd.cfg | sed -n -e 's/^perfdata_spool_dir = //p')
echo "Total files in $spool_perfdata_location" > "/usr/local/nagiosxi/var/components/profile/$folder/file_counts.txt"
-ls -al "$spool_perfdata_location" | wc -l >> "/usr/local/nagiosxi/var/components/profile/$folder/file_counts.txt"
+ls -al "$spool_perfdata_location" 2>/dev/null| wc -l >> "/usr/local/nagiosxi/var/components/profile/$folder/file_counts.txt"
echo "" >> "/usr/local/nagiosxi/var/components/profile/$folder/file_counts.txt"
spool_xidpe_location=$(cat /usr/local/nagios/etc/commands.cfg | sed -n -e 's/\$TIMET\$.perfdata.host//p' | sed -n -e 's/\s*command_line\s*\/bin\/mv\s//p' | sed -n -e 's/.*\s//p')
echo "Total files in $spool_xidpe_location" >> "/usr/local/nagiosxi/var/components/profile/$folder/file_counts.txt"
-ls -al "$spool_xidpe_location" | wc -l >> "/usr/local/nagiosxi/var/components/profile/$folder/file_counts.txt"
+ls -al "$spool_xidpe_location" 2>/dev/null| wc -l >> "/usr/local/nagiosxi/var/components/profile/$folder/file_counts.txt"
echo "Counting MRTG Files..."
Thanks for following up and send over the results. Want to go ahead and rule out permissions, to run the API command with root user permissions.
Some housekeeping; we see that when executing reconfigure_nagios.sh it is trying to import cfg from the /usr/local/nagios/etc/import/. Please review this import and if everything is okay remove files from the import directory. Then re-run the 'reconfigure_nagios.sh' and check for anything that failed.
Verify that the host and services look good in pre-flight with no errors in core by:
Perry
su -l root
curl -XGET "http://127.0.0.1/nagiosxi/api/v1/config/contactgroup?apikey=TOKEN&pretty=1&contactgroup_name" -v --show-error -k
/usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg
Perry
Hi Perry,
What I see through curl is what I see through theweb interface. Here is the output of the curl ran as root (output is the same if run from another host) :
There was no issue in /usr/local/nagios/etc/import, but just to rule this out, we removed all files in /usr/local/nagios/etc/import.
Output of: /usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.
Warnings are about notification periode or interval.
* About to connect() to 127.0.0.1 port 80 (#0)
* Trying 127.0.0.1...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Connected to 127.0.0.1 (127.0.0.1) port 80 (#0)
> GET /nagiosxi/api/v1/config/contactgroup?apikey=8vs6PWilJifCZ7Gn23CCNuNsnVAMihlpQQOFM7ZLIvDXFgkWidulKC7ntHpOe4t4&pretty=1&contactgroup_name HTTP/1.1
> User-Agent: curl/7.29.0
> Host: 127.0.0.1
> Accept: */*
< HTTP/1.1 200 OK
< Date: Mon, 11 Oct 2021 06:13:45 GMT
< Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips mod_fcgid/2.3.9 PHP/5.4.16
< X-Powered-By: PHP/5.4.16
< Access-Control-Allow-Origin: *
< Access-Control-Allow-Methods: POST, GET, OPTIONS, DELETE, PUT
< Transfer-Encoding: chunked
< Content-Type: application/json
{ [data not shown]
"contactgroup_name": "aaaaaaaaaaaa",
"alias": "aaaaaaaaaaaa"
"contactgroup_name": "admins",
"alias": "Nagios Administrators",
"members": [
"nagiosadmin"
Nagios Core 4.
Last Modified: 2020-04-28
License: GPL
Reading configuration data...
Read main config file okay...
Checked 92929 services.
Checked 12752 hosts.
Checked 4644 host groups.
Checked 21 service groups.
Checked 656 contacts.
Checked 283 contact groups.
Checked 853 commands.
Checked 412 time periods.
Checked 0 host escalations.
Checked 12752 hosts
Checked 0 host dependencies
Checked 412 timeperiods
Checking misc settings...
Total Warnings: 4330
Total Errors: 0
Perry,
We are trying to upgrade from 5.5.8 to 5.8.6. Could this issue we're having be related to the upgrade ?
Here how we proceed to upgrade :
- initial : xi 5.5.8 + nagios core 4.2
- upgrade to xi 5.5.9 (using upgrade script)
- upgrade to xi 5.5.11 (using upgrade script)
- upgrade to xi 5.6.14 (using upgrade script)
- upgrade to xi 5.7.5 (using upgrade script)
- upgrade to xi 5.8.6 (using upgrade script)
Ronan
Ronan
Hello Ronan,
What do we see in the 'upgrade.log' located '/usr/local/nagiosxi/tmp/upgrade.log'?
Let us know,
Perry
Let us know,
Perry
