[auth/gensec/gensec.c
[lib/com/dcom/main.c:528:dcom_determine_rpc_binding()] Using binding ncacn_ip_tcp:172.24.57.26
[librpc/rpc/dcerpc_connect.c:513:continue_map_binding()] Mapped to DCERPC endpoint 135
[lib/com/dcom/main.c:413:determine_rpc_binding_continue2()] dcerpc_ndr_request_recv returned NT_STATUS_OK
[lib/com/dcom/main.c:417:determine_rpc_binding_continue2()] IObjectExporter::ServerAlive returned NT_STATUS_OK
[auth/gensec/gensec_gssapi.c:304:gensec_gssapi_client_start()] Cannot do GSSAPI to an IP address
[auth/gensec/gensec.c:606:gensec_start_mech()] Failed to start GENSEC client mech gssapi_krb5: NT_STATUS_INVALID_PARAMETER
[auth/ntlmssp/ntlmssp_client.c:128:ntlmssp_client_challenge()] Got challenge flags:
[auth/ntlmssp/ntlmssp.c:72:debug_ntlmssp_flags()] Got NTLMSSP neg_flags=0x62898205
NTLMSSP_NEGOTIATE_UNICODE
NTLMSSP_REQUEST_TARGET
NTLMSSP_NEGOTIATE_NTLM
NTLMSSP_NEGOTIATE_ALWAYS_SIGN
NTLMSSP_NEGOTIATE_NTLM2
NTLMSSP_CHAL_TARGET_INFO
NTLMSSP_NEGOTIATE_128
NTLMSSP_NEGOTIATE_KEY_EXCH
[auth/ntlmssp/ntlmssp_client.c:242:ntlmssp_client_challenge()] NTLMSSP: Set final flags:
[auth/ntlmssp/ntlmssp.c:72:debug_ntlmssp_flags()] Got NTLMSSP neg_flags=0x60088205
[lib/com/dcom/main.c:570:complete_activation()] Negotiated COM version: 5.1 using binding ncacn_ip_tcp:172.24.57.26[135]
[lib/util/util.c:334:interpret_addr()] sys_gethostbyname: Unknown host. fl1iw1000
[lib/socket/interface.c:103:add_interface()] added interface ip=10.194.12.101 nmask=255.255.255.0
[librpc/rpc/dcerpc_connect.c:329:dcerpc_pipe_connect_ncacn_ip_tcp_recv()] failed NT status (c00000b5) in dcerpc_pipe_connect_ncacn_ip_tcp_recv
[librpc/rpc/dcerpc_connect.c:790:dcerpc_pipe_connect_b_recv()] failed NT status (c00000b5) in dcerpc_pipe_connect_b_recv
[wmi/wmic.c:196:main()] ERROR: Login to remote object.
NTSTATUS: NT code 0xc002001b - NT code 0xc002001b
