SQL Error
sneha.irali
SQL Error
Post by sneha.irali »
Hi Team,
While I enable the Longest transaction parameter I get below error:
What would cause this error, how do we remediate it.
[nagios@SPSLNAGIOS ~]$ /usr/local/nagios/libexec/check_mssql_server.php -H 192.168.16.104 --checktype 'server' -U 'hpmon' -P 'Password@789' --perftype default -p 8043 --mode longesttrans --warning 5 --critical 10
ERROR: [MSSQLQuery::run_on_connection] Query (longesttrans) Failed!! No Results! returnCode [] query [SELECT cntr_value as value, DATEDIFF(SECOND, '1970-01-01', GETUTCDATE()) as utctimestamp FROM sys.dm_os_performance_counters WHERE counter_name='Longest Transaction Running Time' AND instance_name='';] (2175)
ERROR: [MSSQLQuery::run_on_connection] SQLSTATE[HY000]: General error: 20018 The user does not have permission to perform this action. [20018] (severity 16) [(null)] (2176)
CRITICAL: longesttrans query failed. This could be caused by your sysperfinfo not containing the proper entries for this query, and you may need to delete this service check.
gsmith
Re: SQL Error
Post by gsmith »
The first thing to look at is:
Does the user running the query have access to all the tables and permissions to use all the options required by the query?
You could try logging in as root and running the query.
Let me know what you find out.
sneha.irali
Re: SQL Error
As checked with SQL Admin, the privilages are appropriate ( also compared with the working DB) both are same.
Attached the snap for reference.
What would be the next possible thing to check upon.
I would also like to know if SQL DB 2008R2 is compatible with Nagios or no..?
gsmith
Re: SQL Error
Post by gsmith »
Hi
Looks good, thanks for checking. I am not sure if SQL DB 2000R2 is compatible
with Nagios in terms of being monitored by Nagios.
The perftype you have chosen is "default" which looks in the sys.dm_os_performance_counters table found in SQL Server 2008+
You can see this in the error message from the plugin as well:
Please see what happens when you remove the perftype option entirely.
sneha.irali
Re: SQL Error
Please see what happens when you remove the perftype option entirely. - how do I do this..?
gsmith
Re: SQL Error
Post by gsmith »
Sorry about that.
Change:
to:
/usr/local/nagios/libexec/check_mssql_server.php -H 192.168.16.104 --checktype 'server' -U 'hpmon' -P 'Password@789' -p 8043 --mode longesttrans --warning 5 --critical 10
Let me know what the results are please.
sneha.irali
Re: SQL Error
Error remains same:
[root@SPSLNAGIOS libexec]# ./check_mssql_server.php -H 192.168.16.104 --checktype 'server' -U 'hpmon' -P 'Password@789' -p 8043 --mode longesttrans --warning 5 --critical 10
gsmith
Re: SQL Error
Post by gsmith »
Please give this command a try:
/usr/local/nagios/libexec/check_mssql_server.php -H 192.168.16.104 --checktype 'server' -U 'hpmon' -P 'Password@789' --perftype deprecated -p 8043 --mode longesttrans --warning 5 --critical 10
Let me know how that works for you.
sneha.irali
Re: SQL Error
Hi gsmith,
its still the same:
[root@SPSLNAGIOS ~]# /usr/local/nagios/libexec/check_mssql_server.php -H 192.168.16.104 --checktype 'server' -U 'hpmon' -P 'Password@789' --perftype deprecated -p 8043 --mode longesttrans --warning 5 --critical 10
ERROR: [MSSQLQuery::run_on_connection] Query (longesttrans) Failed!! No Results! returnCode [] query [SELECT cntr_value as value, DATEDIFF(SECOND, '1970-01-01', GETUTCDATE()) as utctimestamp FROM sys.sysperfinfo WHERE counter_name='Longest Transaction Running Time' AND instance_name='';] (2175)
gsmith
Re: SQL Error
Post by gsmith »
hi
I'd like to verify which table is being used for the system performance issue so please do the following:
login to mssql as user hpmon and password Password@789
then run:
select count(*) from sys.sysperfinfo;
select count(*) from sys.dm_os_performance_counters
