Hi Team,
I have installed nagios xi trail version installation completed , I want to monitor aws ec2 instance's . I have gone through configure and selected configuration wiazrd --> ec2 instance. It shows specify either an accesskeyid and Secret key id . But i didn't see where do in need to enter this keys.
Please help on this asap.
Dheeraj.
unable to configure ec2 instance
Re: unable to configure ec2 instance
Hi
Does your Config Wizard look like this: If it doesn't please send a screenshot of what you are seeing.
