simplest way to move data
benhank
Post by benhank »
My LS cluster is moving to new hardware.
whats the simplest way to move the data from the old cluster to the new ?
Proudly running:
Nagios Network Analyser
Nagios Fusion
kfanselow
Re: simplest way to move data
Post by kfanselow »
Probably the easiest route to migrate the logdata would be to create a snapshot and restore the data to the new server.
Configure (top) -> Configure Snapshots (left) - and then create a new snapshot which can be found in the directory:
/usr/local/nagioslogserver/snapshot
Copy the snapshot file to your new system to the new system and restore.
If you need to migrate the configuration information as well you can use the system backups which can be found here:
/store/backups/nagioslogserver/
More information about Backing Up And Restoring Nagios Log Server can be found here:
https://assets.nagios.com/downloads/nag ... Server.pdf
More information about Managing Snapshots can be found here:
https://assets.nagios.com/downloads/nag ... enance.pdf
Thanks and Best Regards,
Keith
benhank
Post by benhank »
thank you!
Proudly running:
Nagios Fusion
benjaminsmith
Post by benjaminsmith »
Hi Ben,
Glad that was helpful. Did you have any other questions or shall we mark this as resolved?
Let us know when you have a chance.
benhank
Post by benhank »
I do have one more question:
I want to use rsync to copy the data from the old cluster to the new cluster and get5 the data working on the new.
How would I do that?
Proudly running:
Nagios Fusion
kfanselow
Post by kfanselow »
Hi benhank,
If you're looking to move the snapshot data between the machines here is the manual page for rysnc, however I think it might be easier just to scp it between the two hosts.
https://www.freebsd.org/cgi/man.cgi?que ... ormat=html
However If you are trying to sync the elasticsearch data while it's running I'm not sure if or how that can be done; please let us know if you can find a way - we'd love to hear about it.
Keith
benhank
Post by benhank »
So far here is what I have done:
on old cluster :
1. shutdown Elasticsearch on node 2 of the old cluster. (this node does not ingest data)
 systemctl stop elasticsearch.service
2. I have a single node test NLS server which is not ingesting data so I shut down elasticsearch on it:
then I copied the data from the old to the test server:
 rsync -avzhe ssh benhanker@lNLSp01:/usr/local/nagioslogserver/elasticsearch/data/c9dc126e-346d-4bfa-a30e-14b849c50ab5 /scratch/nlsdata/
and started the service:
systemctl start elasticsearch.service
The old cluster has 180 days of data but after copying the files I don't see it.
Proudly running:
Nagios Fusion
ssax
Dreams In Code
Post by ssax »
Everywhere I've found says that what you're trying to do will have issues because of the way it is stored and the cluster being different.
The recommendation would be to use snapshots and then restore them on the new cluster as moving the data from the old system is an unsupported process (that is what the snapshots are for).
benhank
Post by benhank »
ok you can lock it up and thanks!
Proudly running:
Nagios Fusion
benjaminsmith
Hi Ben,
Sounds good. If you need help with anything else, feel free to reach out.
