--2021-10-20 10:42:00-- http://assets.nagios.com/downloads/nagi ... .amd64.deb
Resolving assets.nagios.com (assets.nagios.com)... 45.79.49.120, 2600
Connecting to assets.nagios.com (assets.nagios.com)|45.79.49.120|:80... failed: Connection refused.
Connecting to assets.nagios.com (assets.nagios.com)|2600
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The log suggests running full install again and when I do that it says its already installed and to run upgrade. When I do the upgrade it says it is successful and I can load it on the web browser but I cannot. I noticed in my firewall that it appears to potentially have blocked some port 80 traffic at the time and I am wondering if that was the issue? How can I proceed - I could open the firewall to finish the install but how do I uninstall to do the re-install - or is there a better option?
The step that failed was: 'wkhtmltopdf'
