Getting error setting up autodiscovery, all pre-requisite are there, some past posts talk about run setup.sh. This is not in the DIR, running rhel7.
/usr/local/nagiosxi/html/includes/components/autodiscovery/setup.sh is not there
An installation errror was detected. The following steps must be completed before using this component:
Make sure pre-requisite programs are installed. The following programs must be installed on your Nagios XI server:
fping (/usr/sbin/fping or /usr/bin/fping)
traceroute (/bin/traceroute or /usr/bin/traceroute)
nmap (/usr/bin/nmap)
Auto Discovery pre-req errors
Re: Auto Discovery pre-req errors
Hello @trondeau
Thanks for reaching out, what do you see when you go to the web UI > Configure > Auto-Discovery? Are the php-components up-to-date. Found in: '/usr/local/nagiosxi/basedir/html/includes/components/autodiscovery/autodiscovery.inc.php'
Perry
Perry
