NagiosCore-Received disconnect from UNKNOWN port 65535:2
Venky4u
Post by Venky4u »
Hello Team,
I'm using NagiosCore 4.4.6 with Nagios-plugins version 2.2.1
I haven't faced any issue while working on the RHEL-7 box where NagiosCore was installed. The moment I migrated to RHEL-8, I'm facing the issue. Where I'm getting desired output while executing the scripts from Nagios command line but the Nagios web interface is throwing the below error.
Error from Web UI: "UNKNOWN Remote command execution failed: Received disconnect from UNKNOWN port 65535:2: Too many authentication failures"
Command line: [devops@cvlappxd21871 libexec]$ ./check_by_ssh -H host -l devops -C '/home/devops/nagiosScripts/check_tomcat.sh'
/opt/jboss/jws-5.3/servers/tomcat_1 is running
I have checked the permissions and everything looks fine.
User:devops
[devops@cvlappxd21871 .ssh]$ ls -la
total 8
drwx------. 2 devops devops 38 Oct 6 11:06 .
drwxr-x---. 3 devops devops 125 Oct 25 10:47 ..
-rw-------. 1 devops devops 2622 Oct 6 11:06 id_rsa
-rw-r--r--. 1 devops devops 585 Oct 6 11:06 id_rsa.pub
Please do the needful.
Regards,
Venkatesh Y
benjaminsmith
Re: NagiosCore-Received disconnect from UNKNOWN port 65535:2
Post by benjaminsmith »
Hi Venkatesh,
Based on that error message, it's probably not an issue directly related to Nagiso but a configuration issue with SSH. Try following the steps in the article below to resolve and let us know how that goes.
How to Fix “SSH Too Many Authentication Failures” Error
--Benjmain
Venky4u
Post by Venky4u »
Before trying the steps that you have provided in the article, I did and ssh -vvv to the target host with devops ID and attached the verbose output.
I have tried the above steps but no luck. I still see the same error "UNKNOWN Remote command execution failed: Received disconnect from UNKNOWN port 65535:2: Too many authentication failures"
[devops@Nagios-server .ssh]$ cat config
Host hostname
IdentitiesOnly=yes
PreferredAuthentications=publickey
LogLevel INFO
Regards,
Venkatesh Y
SSH connection.txt
(13.96 KiB) Downloaded 372 times
Venky4u
Post by Venky4u »
Can someone help me on this issue ?
Regards,
Venkatesh Y
