"MIB could not be installed"
kcarlson
Post by kcarlson »
Hello, trying to load various MIBs using the manager within the XI web interface. Every attempt gives me the error that the mib could not be installed. Looking at /var/log/httpd/error_log I see some permissions errors related to my mibs. When performing a 'ls -l' on the file in question I show:
-rwxrwxrwx. 1 nagios nagios 46941 Sep 13 09:09 /usr/local/nagiosxi/html/admin/mibs.php
I have attached the output of the permissions errors when viewing the httpd error log. Any help getting this resolved would be appreciated. I can also provide the MIB(s) I am trying to load if that is helpful.
Thanks!
Re: "MIB could not be installed"
The permissions to the folder where the php script is copying the files is probably causing the issue.
To set the permissions, run the following as root.
chown root.nagios /usr/share/snmp/mibs
chmod 0664 ​/usr/share/snmp/mibs
chmod g+s ​/usr/share/snmp/mibs
chown root.nagios /usr/share/snmp/mibs/*
chmod 0664 ​/usr/share/snmp/mibs/*
Then see if you can add the MIB file to the XI server.
Thank you.
kcarlson
Post by kcarlson »
Thank you for the quick reply. I have performed the changes you suggested but am still unable to load a MIB. I have attached the most recent results of the httpd error log.
Also, after making those changes we received a "problem service alert" notifying us of the following:
External command error: /usr/share/snmp/mibs/E7-Calix-MIB.txt: Permission denied
Date/Time: 2021-10-28 09:50:40
Thanks!
What version of XI is the server running and what is the OS and release of the system?
Open a root shell on the Nagios server, run the following commands and post the /tmp/info.txt file to the ticket.
chage -l nagios >/tmp/info.txt
df -h >>/tmp/info.txt
df -i >>/tmp/info.txt
grep nag /etc/group >>/tmp/info.txt
ls -l /tmp >>/tmp/info.txt
ls -lR /usr/share/snmp >>/tmp/info.txt
Thank you.
kcarlson
Post by kcarlson »
We are running 5.8.6 of XI and the server is running CentOS 7.
/tmp/info.txt should be attached.
There are some additional permission changes that need to be done.
Run this as root.
chmod 0775 ​/usr/share/snmp/mibs
chmod 0775 ​/usr/share/snmp/mibs/processed_mibs
chmod g+s ​/usr/share/snmp/mibs/processed_mibs
Then see if you can upload the MIB file.
Thank you.
kcarlson
Post by kcarlson »
Your last suggestion appears to have fixed my issue. Thank you for your time.
Thanks!
Your welcome. Glad it is all working for you now.
