ANyone can help how can i configure SNMP TRAP Definition when i have the MIB file?
when I upload the MIB and check mark process traps, I'm getting below Error:
snmpttconvertmib is not in the correct location or is not installed. If you have not run the Nagios XI SNMP Integration script it is located here. rc 1
searching solution refer me to this site : http://snmptt.sourceforge.net/docs/snmp ... tmib.shtml
but i don't understand what exactly i need to run.
How to create SNMP TRAP Definition from MIB File
fahad.abdullah
Re: How to create SNMP TRAP Definition from MIB File
You can follow this guide here if you have the Enterprise License add-on (see page 13 specifically for uploading MIBs):
https://assets.nagios.com/downloads/nag ... ios_XI.pdf
See here as well:
https://support.nagios.com/kb/article/n ... s-852.html
Or here if you do not have the Enterprise License add-on:
Let us know if you have any questions.
Thank you!
See here as well:
Thank you!
