XI event logs page blank
mrjsokol
Post by mrjsokol »
Good morning all,
We have an issue we noticed in 5.8.6 of XI that our event logs are showing blank. We do not know how long this issue persisted as we do not often use this page. See SS attached.
pbroste
Re: XI event logs page blank
Post by pbroste »
Hello @mrjsokol
Thanks for reaching out, took a look through solutions related to this issue and see that we need to take a look at your environment using your System Profile so we can narrow things down.
Please provide the results on the following and PM your updated system profile for us to review.
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
To send us your system profile.
  • Login to the Nagios XI GUI using a web browser.
  • Click the "Admin" > "System Profile" Menu
  • Click the "Download Profile" button
  • Save the profile.zip file and send via Private Message
Perry
mrjsokol
Post by mrjsokol »
Sent a profile and waiting for infrastructure to run the SQL statement.
pbroste
Post by pbroste »
Hello @mrjsokol
Thanks for sending over the system profile, after review we see that there are database errors and want to start by running through the database repair.
Let's start off by looking through the columns to make sure that there isn't anything exceedingly large.
[/list]
Let us know how things are looking.
Perry
mrjsokol
Post by mrjsokol »
Sent a pm of the SQL results and the repair script was ran prior to making the post.
pbroste
Post by pbroste »
Hello @mrjsokol
Followed up with a pm reply, please follow up on this thread when you have sent the requested info.
Perry
pbroste
Post by pbroste »
Hello @mrjsokol
Thanks for following up and sending over the updated System Profile, we see that the 'logs' table did not get repaired due to the size.
You will need to truncate these tables then run the repair on the database. Example:
mysql -u ndoutils -pn@gweb nagios -e 'TRUNCATE TABLE nagios_logentries'
Note: You will lose the historical data that was stored in these tables.
For more info, read the following document:
http://assets.nagios.com/downloads/nagi ... tabase.pdf
Perry
mrjsokol
Post by mrjsokol »
Good evening,
After truncating the table we made some progress! We now are seeing events show up in the events but seeing the following for most events
See attachment
pbroste
Post by pbroste »
Hello @mrjsokol
Sounds like progress, let's take a look at the updated System Profile to see what is going on.
Perry
mrjsokol
Post by mrjsokol »
Hey Perry sorry for the delay. I have sent you the latest profile.
