Can I get Generate a Report from a deleted server
spcmidrange
Post by spcmidrange »
Good Day
So we decommissioned some servers, and removed them from nagios. Now been asked to get a report of availability of them to compare against the newer ones. I do not see them as hosts to choose to make reports from anymore
I have 4 years of archive logs. Is there anyway i can generate reports on older hosts?
Thanks in advance!
gsmith
Re: Can I get Generate a Report from a deleted server
Post by gsmith »
Hi
I believe it's possible but I am going to try it with a test environment.
Besides the archives, can you please tell me if the directory for the deleted server
exists in /usr/local/nagios/share/perfdata ?
Thanks!
spcmidrange
Apologies for the late reply
Yes, that folder has the data from the servers that have been deleted
Cheers!
gsmith
Post by gsmith »
Hi
Thanks. I am doing some testing. Will let
you know what I find out.
gsmith
Post by gsmith »
We tried a couple of things but couldn't get good results accessing the data in /usr/local/nagios/share/perfdata
on the current server.
If you have XI backups you can spin up another server, install the same version of XI,
restore to it and access the data.
