Hi Team,
We wanted to have a home page in Nagios Log Server more inclined towards the stats of hosts from which we are receiving logs.
Is there any way we can completely customize the home page?
Thanks in advance
Customizing Nagios Log Server Home page
DhananjayaPatil
Re: Customizing Nagios Log Server Home page
Hello @DhananjayaPatil
The option to create a default Dashboard and use that as the home page would be recommended. The default home page on the backend is: '/var/www/html/nagioslogserver/www/index.php', we do not recommend editing it but if you do please make sure that you create a backup.
Perry
Perry
DhananjayaPatil
Hi pbroste,
Just wanted to know one more thing, is the homepage modifiable from the frontend itself ?
Thanks for following up, the default homepage is not modifiable but the option to configure Dashboard(s) is.
Perry
Perry
