Nagios License Check
durgaraoyv
Post by durgaraoyv »
Hi
Please let us know what security impact will be there if "Insecure logins" enabled ?
Is internet access a must to have the Nagios license check implemented ?
https://assets.nagios.com/downloads/nag ... -Check.pdf
Please let us know if any alternative to have this check?
Thank you.
benjaminsmith
Re: Nagios License Check
Post by benjaminsmith »
Unless it's an offline install, the server must have access to the internet to reach out license server (api.nagios.com).
Insecure logins are allowed by passing a user generate a ticket in the URL string for authentication. For this particular check, it's running the URL string against itself, but I would recommend setting up SSL/TLS on the system as well. That said, enabling insure logins is going to be less secure than not.
See:How To Configure SSL/TLS
Let us know if you have any other questions.
-Benjamin
