NCPA agent detected another listener running
stepchi
Post by stepchi »
Our NCPA agent running on Ubuntu 16.04 showed an "Active (exited)" status when checking with "systemctl status ncpa_listener". When we looked back in the syslog we saw the following:
Nov 2 08:51:34 pxxxx ncpa_listener[3178]: Started NCPA Listener
Nov 2 09:20:00 pxxxx systemd[1]: Started LSB: This manages the NCPA Passive service.
Nov 2 09:20:00 pxxxx ncpa_listener[3234]: another instance seems to be running (pid 3290), exiting
We'd like to know how NCPA finds out whether there's an instance already running.
Steve
kfanselow
Re: NCPA agent detected another listener running
Post by kfanselow »
Hi Steve,
NCPA looks for another running instance by locating and validating the contents of the process identification (pid) file:
/usr/local/ncpa/var/run/ncpa_listener.pid
/usr/local/ncpa/var/run/ncpa_passive.pid
The routine for the listener can be found here (check_pid function starts on line 320):
https://github.com/NagiosEnterprises/nc ... adaemon.py
Thanks and Best Regards,
Keith
