I am seeing this when trying to login to network analyzer from chrome - Not Found
The requested URL /nagiosna/login was not found on this server.
It works from Firefox though. Other people are experiencing the same issue as me so its not just my browser.
404 Error for Network Analzer
Re: 404 Error for Network Analzer
Some people are also having the issue on Firefox and edge too. So not sure why it works sometimes for some people.
Whatever the issue it appears to go away after I enabled SSL and configured it.
What OS/version is it running?
If running RHEL/CENT/ORACLE, run this command as root:
If running Debian/Ubuntu, run this command as root:
Then PM me the resulting /tmp/HTTPDFILES.zip file.
You can use WinSCP to download it from your XI server.
uname -a
cat /etc/*releaseCode: Select all
zip -r /tmp/HTTPDFILES.zip /etc/httpd/conf/httpd.conf /etc/httpd/conf.dCode: Select all
zip -r /tmp/HTTPDFILES.zip /etc/apache2You can use WinSCP to download it from your XI server.
