From nagiosXI it showing connection reset by peer when I check in the logs showing this error message, have no idea to check what's the problem
[root@serverlog]# cat ncpa_listener.log
2021-11-10 01:34:12,182 4087067 INFO started
2021-11-10 01:34:12,182 4087067 ERROR attempt to write a readonly database
Traceback (most recent call last):
File "/root/ncpa/agent/listener/database.py", line 54, in run_db_maintenance
OperationalError: attempt to write a readonly database
2021-11-10 01:34:12,183 4087067 INFO Using SSL version TLSv1_2
2021-11-10 10:48:46,687 4087067 INFO stopped
2021-11-10 10:48:50,327 185951 INFO started
2021-11-10 10:48:50,328 185951 ERROR attempt to write a readonly database
2021-11-10 10:48:50,328 185951 INFO Using SSL version TLSv1_2
[root@serverlog]# rpm -qa| grep ncpa
ncpa-2.3.1-1.el8.x86_64
