CUSTOM plugins fro XI monitoring
ITOMB_IMT
Post by ITOMB_IMT »
I have some questions regarding custom plugins. Earlier we used write a custom plugin for monitoring purpose and store it in /usr/lib/libexec on remote server and configure it in nrpe.cfg.
1. can we store the custom plugin on nagios server and monitor? if so what type of access is required by nagios user on remote server.
2. How to configure custom plugin for monitoring from Nagios server?
kfanselow
Re: CUSTOM plugins fro XI monitoring
Post by kfanselow »
Hi TOMB_IMT,
The answers to these questions will depend upon the nature of the system, script and what it is checking. Generally speaking with most UNIX/Unix Like systems a lot of things can be checked in more than one way such as SNMP or using a plugin such as 'check_by_ssh'. What type of script is it and what are you checking ?
Also - for convenience sake here is some of our documentation that you might find useful:
Plugin API page:
https://assets.nagios.com/downloads/nag ... inapi.html
Plugin Development Guidelines:
http://nagios-plugins.org/doc/guidelines.html
And the Manual Page for check_by_ssh:
https://nagios-plugins.org/doc/man/check_by_ssh.html
Thanks and Best Regards,
Keith
ITOMB_IMT
Post by ITOMB_IMT »
Thanks for your response. Currently i have custom scripts written and stored in remote server. They were configured in nrpe.cfg file and providing desired results.
Let me say for example, i have check_disk plugin stored and configured in nrpe.cfg file on remote server and the service is defined as follows in nagios server.
host_name remote_server
service_description / Disk Usage
use xiwizard_nrpe_service
check_command check_nrpe!check_disk!-a '-w 15% -c 10% -p /'!!!!!!
initial_state o
max_check_attempts 1
check_interval 5
retry_interval 1
active_checks_enabled 1
notification_interval 10
notification_options w,c,u,r,
notifications_enabled 1
contacts nagiosadmin
_xiwizard linux-server
register 1
I don't want the plugin to be stored on remote server and to be configured in remote server. as we are planning to add more and more servers, its difficult to copy plugins and configure in nrpe.cfg file on all servers.
I just want to store the plugins stored on nagios server instead of remote server and start monitoring. Please let me know if there is a way.
ssax
Dreams In Code
Post by ssax »
It's not possible with NRPE, you can do centralized config/plugin management with with NRDS though:
https://assets.nagios.com/downloads/nag ... h_NRDS.pdf
If you needed it for NRPE you'd need to use a solution such as ansible or some other config management solution.
kfanselow
Post by kfanselow »
Hi ITOMB_IMT,
I see you're using NRPE currently and we are working to move customers to NCPA where practical to both for ease of management and because NCPA is going to our supported agent moving foward. NCPA can be installed and managed through the XI console (Configure -> Deploy Agent) which makes it easier to use however if you want to avoid using an agent all together you can use SNMP or run commands on the remote system using plugins like check_by_ssh.
Here's our knowledge base article on monitoring Linux based system using SNMP:
https://assets.nagios.com/downloads/nag ... g-SNMP.pdf
Also here is the manual page for our check_by_ssh plugin:
Hope this is useful,
Keith
ITOMB_IMT
Post by ITOMB_IMT »
hi,
Thanks for your response on doing to through NRDS for Linux servers. How can i do it with NCPA for windows servers?
ssax
Dreams In Code
Post by ssax »
NCPA doesn't currently support it.
NRDS (for Windows and Linux) is currently the only method that allows centralized config/plugin management.
