Caught SIGTERM shutting down
gregwhite
Post by gregwhite »
Today NagiosXI suddenly stopped. When I checked the event log I found an error "Caught SIGTERM shutting down". I restarted Nagios and it seems to be working now. My concern is if it happens again and goes unnoticed. What causes this and can it be prevented?
Greg
pbroste
Re: Caught SIGTERM shutting down
Post by pbroste »
Hello @gregwhite
Thanks for reaching out, typically the SIGTERM” signal indicates that some process is sent a signal to shutdown a process or service for various reasons. Suggestion to take a look at the events that surround the "SIGTERM" may find another event that caused it. So when a process receives SIGTERM, some other process sent that signal:
grep -Eir "Caught SIGTERM|Caught SIGSEGV" /usr/local/nagios/var/nagios.log /var/log/messages /var/log/syslog --color=always -A 4 -B 2 | less -SR
Want to check to see if there are any Add-on brokers configured:(like mod_gearman, livestatus, ndo, etc)
grep broker /usr/local/nagios/etc/nagios.cfg
Here is also a support article that goes over some optimizations that you can check.
https://assets.nagios.com/downloads/nag ... uning.html
Perry
