Hi
We are experiencing that certain logfiles seem to grow quite quickly.... these seem to be the main culprits: (in no particular order)
/var/lib/mysql/xi_auditlog.ibd 159.383.552
nagios_logentries.MYD
nagios_logentries.MYI
nagios_notifications.MYD
/usr/local/nagios/var/nagios.log
you can adjust how long information is to be retained in Performance Settings>Database, which will affect the size of the files I suppose.
But i am a little lost with regards to which parameters that affect these logs? All of these?
Max External Commands Age: Max time in DAYS to keep external commands.
Max Log Entries Age: Max time in DAYS to keep log entries.
Max Notifications Age: Max time in DAYS to keep notifications.
Max State History Age: Max time in DAYS to keep state history information.
And if the files have already grown excessive due to default settings or otherwise, what can be done about it? If I reduce the "Max DAYS" settings, the files will not be pruned/reduced in size.... what can I do?
regards,
Håkon
What to do with excessive log file/database file sizes?
Re: What to do with excessive log file/database file sizes?
Hi
Here is a good document describing the settings you refer to:
https://assets.nagios.com/downloads/nag ... 1773666937
You are correct that making changes to these settings will not affect the already created logs.
Once you decide on the what settings you want to use for your installation you can edit the existing files
so that they reflect what these settings are. This can be done using a text editor like
vi/nano/atom
Here is another document describing the logs and their locations:
https://assets.nagios.com/downloads/nag ... ptions.pdf
Please let us know if you have anymore questions.
vi/nano/atom
Hi
Thank you for your references to the documents... i have tried to study them but I have to concede that i still dont find any answers to my questions.
So let's take something very concrete:
I have been trying to limit the file /usr/local/nagios/var/nagios.log from growing excessively.
The document states that this file is rotated daily, which the config file indeed indicates (?) : log_rotation_method=d
A new file seems to be generated daily in the /archives folder, but the original nagios.log file just keeps growing, so this doesn't solve my problem.
Also, I have tried, somewhat randomly as I don't know which is which, to set all the DAYS settings of Admin>performance>databases down to 1, but this does not seem to have any effect ion anything.
Can you please explain how the rotation is supposed to work + which >Databases settings should affect which files?
benjaminsmith
If you do not care about saving this data, you can manually delete the older files in that folder.
Let's get an output of the table sizes. Please post the output to the following command. Thanks, Benjamin
So Nagios XI, does not delete any of the nagios.log files. They are rotated daily into the archives folder but never deleted. However, they are just text files and even a larger Nagios XI installation requires less than 100 GB of disk space to run.I have been trying to limit the file /usr/local/nagios/var/nagios.log from growing excessively.
That should have an effect, however, it would not make a change to the database until the database maintenance script runs, every 5 minutes.Also, I have tried, somewhat randomly as I don't know which is which, to set all the DAYS settings of Admin>performance>databases down to 1, but this does not seem to have any effect ion anything.
echo "SELECT table_name AS 'Table', round(((data_length + index_length) / 1024 / 1024), 2) 'Size in MB' FROM information_schema.TABLES WHERE table_schema IN ('nagios', 'nagiosql', 'nagiosxi');" | mysql -h 127.0.0.1 -uroot -pnagiosxi --table
