VMWARE monitors not Working after installing SDK
faizanmalik
Post by faizanmalik »
Hi Folks,
I recently installed VMware SDK 7 but im getting below mentioned error. Any suggestions here?
OS version: CentOS Linux release 8.4.2105
Installed SDK: VMware-vSphere-Perl-SDK-7.0.0-16815913.x86_64.tar.gz
Error: Unknown-VMWARE_API UNKNOWN - Failed to load module VMware::VIRuntime. Download and install 'VMware vSphere SDK for Perl', available at https://my.vmware.com/group/vmware/downloads
Full error message: Can't locate VMware/VIRuntime.pm in @INC (you may need to install the VMware::VIRuntime module) (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5) at /usr/local/nagios/libexec/check_vmware_api.pl line 546.
Installed modules are:
App::cpanminus
Bytes::Random::Secure
Capture::Tiny
Class::Accessor
Convert::ASN1
Crypt::OpenSSL::Bignum
Crypt::OpenSSL::Guess
Crypt::OpenSSL::RSA
Crypt::OpenSSL::Random
Crypt::Random::Seed
Crypt::Random::TESHA2
Crypt::SSLeay
Crypt::X509
Devel::CheckLib
Exception::Class
Getopt::Long
HTTP::Date
IO::Interactive::Tiny
List::MoreUtils
List::MoreUtils::XS
Math::Random::ISAAC
Mock::Config
Module::Build
Nagios::Monitoring::Plugin
Net::INET6Glue
Params::Validate
Path::Class
Perl
Test::Fatal
Test::LeakTrace
Test::NoWarnings
Test::Requires
Time::Duration
Time::HiRes
UUID
UUID::Random
Best,
Fai
gsmith
Re: VMWARE monitors not Working after installing SDK
Post by gsmith »
Did you install the prerequisites for the Perl SDK ?
You might as well go ahead and run these:
yum install -y libxml2-devel libxml2 libuuid-devel perl-XML-LibXML perl-Env
yum remove perl-Crypt-SSLeay -y
export PERL_MM_USE_DEFAULT=1
cpan -i App::cpanminus
cpanm Crypt::SSLeay --dev
cpan -i Nagios::Monitoring::Plugin Nagios::Monitoring::Plugin::Functions
Let me know how you make out.
Thanks!
faizanmalik
Yes, i have installed the SDK pre-reqs.
1 cmd from the list has error. (cpanm Crypt::SSLeay --dev) (error: Finding Crypt::SSLeay on cpanmetadb failed)
[root@lnagiosapp ~]# yum install -y libxml2-devel libxml2 libuuid-devel perl-XML-LibXML perl-Env
Failed loading plugin "changelog": bad magic number in 'six': b'\x03\xf3\r\n'
Failed loading plugin "product-id": bad magic number in 'six': b'\x03\xf3\r\n'
Failed loading plugin "subscription-manager": bad magic number in 'six': b'\x03\xf3\r\n'
Failed loading plugin "upload-profile": bad magic number in 'six': b'\x03\xf3\r\n'
Failed loading plugin "spacewalk": bad magic number in 'six': b'\x03\xf3\r\n'
Last metadata expiration check: 1:49:23 ago on Thu 18 Nov 2021 05:12:09 PM IST.
Package libxml2-devel-2.9.7-9.el8_4.2.x86_64 is already installed.
Package libxml2-2.9.7-9.el8_4.2.x86_64 is already installed.
Package libuuid-devel-2.32.1-28.el8.x86_64 is already installed.
Package perl-XML-LibXML-1:2.0132-2.el8.x86_64 is already installed.
Package perl-Env-1.04-395.el8.noarch is already installed.
Dependencies resolved.
Nothing to do.
Complete!
You have new mail in /var/spool/mail/root
[root@lnagiosapp ~]# yum remove perl-Crypt-SSLeay -y
No match for argument: perl-Crypt-SSLeay
No packages marked for removal.
Nothing to do.
Complete!
[root@lnagiosapp ~]# export PERL_MM_USE_DEFAULT=1
[root@lnagiosapp ~]# cpan -i App::cpanminus
Loading internal null logger. Install Log::Log4perl for logging messages
Reading '/root/.local/share/.cpan/Metadata'
Database was generated on Wed, 27 Oct 2021 05:55:50 GMT
CPAN: LWP::UserAgent loaded ok (v6.34)
CPAN: Time::HiRes loaded ok (v1.9764)
Fetching with LWP:
http://www.cpan.org/authors/01mailrc.txt.gz
Reading '/root/.local/share/.cpan/sources/authors/01mailrc.txt.gz'
CPAN: Compress::Zlib loaded ok (v2.081)
............................................................................DONE
Fetching with LWP:
http://www.cpan.org/modules/02packages.details.txt.gz
Reading '/root/.local/share/.cpan/sources/modules/02packages.details.txt.gz'
Database was generated on Thu, 18 Nov 2021 12:41:02 GMT
New CPAN.pm version (v2.28) available.
[Currently running version is v2.18]
You might want to try
install CPAN
reload cpan
to both upgrade CPAN.pm and run the new version without leaving
the current session.
Fetching with LWP:
http://www.cpan.org/modules/03modlist.data.gz
Reading '/root/.local/share/.cpan/sources/modules/03modlist.data.gz'
DONE
Writing /root/.local/share/.cpan/Metadata
CPAN: Module::CoreList loaded ok (v5.20181130)
App::cpanminus is up to date (1.7044).
[root@lnagiosapp ~]# cpanm Crypt::SSLeay --dev
! Finding Crypt::SSLeay on cpanmetadb failed.
! cannot open file '/root/.cpanm/sources/http%www.cpan.org/02packages.details.txt.gz': No such file or directory opening compressed index
! Couldn't find module or a distribution Crypt::SSLeay
[root@lnagiosapp ~]# cpan -i Nagios::Monitoring::Plugin Nagios::Monitoring::Plugin::Functions
Nagios::Monitoring::Plugin is up to date (0.51).
Nagios::Monitoring::Plugin::Functions is up to date (0.51).
Regards,
Fai
gsmith
Post by gsmith »
hi
From a command line please run:
wget http://www.cpan.org/modules/02packages.details.txt.gz
Was it able to get the file?
If not there is probably a proxy server between your server and the internet.
To add your proxy setting to cpan:
cpan
 o conf /proxy/
Now look at your value for http_proxy, if it is empty proceed with next line:
 o conf init http_proxy
Type ENTER, then enter the value.
 http_proxy         [http://my_url_to_proxy:my_port]
Please let me know if that was the problem or if it is still causing problems.
faizanmalik
cpan is already configured with proxy. i was able to download the file from
However, now i saw that the below file does not exist: (VMware folder also didnt exist)
/usr/share/perl5/VMware/VICommon.pm
output:
cd /usr/local/share/perl5/
App/ Devel/ Math/ Test/
Bytes/ Exception/ Mock/ Time/
Capture/ Getopt/ Module/ UUID/
Class/ HTTP/ Nagios/ x86_64-linux-thread-multi/
Convert/ IO/ Net/
Crypt/ List/ Path/
vmware SDK was installed also several times. i doesn't show any errors.
[# ./vmware-install.pl EULA_AGREED=yes
A previous installation of vSphere CLI has been detected.
The previous installation was made by the tar installer (version 4).
Keeping the tar4 installer database format.
/etc/vmware-vcli/installer.sh: line 186: db_answer_--EULA_AGREED=yes: command not found
You have a version of vSphere CLI installed. Continuing will remove it in
preparation for installing a new vSphere CLI. Do you want to continue?
[yes]
Uninstalling the tar installation of vSphere CLI.
The removal of vSphere CLI 7.0.0 build-16815913 for Linux completed
successfully.
Installing vSphere CLI 7.0.0 build-16815913 for Linux.
Not tested with Net::FTP version 3.11 at /usr/local/share/perl5/Net/INET6Glue/FTP.pm line 15.
somebody else already implements FTP IPv6 support - skipping Net::INET6Glue::FTP
In which directory do you want to install the executable files?
[/usr/bin]
Please wait while copying vSphere CLI files...
The installation of vSphere CLI 7.0.0 build-16815913 for Linux completed
successfully. You can decide to remove this software from your system at any
time by invoking the following command:
"/usr/bin/vmware-uninstall-vSphere-CLI.pl".
This installer has successfully installed the vSphere SDK for Perl.
The following Perl modules were found on the system but may be too old to work
with vSphere CLI:
Socket6 0.28 or newer
Enjoy,
--the VMware team
gsmith
Post by gsmith »
Hi
It looks like the Perl SDK installed correctly, even though there might be an issue with IP v6
connections.
Did you try running the VMWare Config Wizard?
faizanmalik
Yes i ran the VMWare wizard and added the host, but getting same error UNKNOWN (screenshot attached)
Full error Below:
Unknown
Download the latest version of the vSphere SDK for Perl from VMware.
In this example we use VMware-vSphere-Perl-SDK-5.1.0-780721.x86_64.tar.gz,
but the instructions should apply to other versions as well.
You may need to install additional packages and Perl modules on your server,
see https://kb.op5.com/x/pYEK for
more information and package names for op5 APS / CentOS 6 / RHEL 6.
Upload the .tar.gz file to your op5 Monitor server's /root dir and execute:
cd /root
tar xvzf VMware-vSphere-Perl-SDK-5.1.0-780721.x86_64.tar.gz
cd vmware-vsphere-cli-distrib/
./vmware-install.pl
Follow the on screen instructions, described below:
"Creating a new vSphere CLI installer database using the tar4 format.
Installing vSphere CLI 5.1.0 build-780721 for Linux.
You must read and accept the vSphere CLI End User License Agreement to
continue.
Press enter to display it."
<ENTER>
"Read through the License Agreement"
"Do you accept? (yes/no)
yes
"In which directory do you want to install the executable files? [/usr/bin]"
<ENTER>
"Please wait while copying vSphere CLI files...
The installation of vSphere CLI 5.1.0 build-780721 for Linux completed
This installer has successfully installed both vSphere CLI and the vSphere SDK
for Perl.
with vSphere CLI:
Compress::Zlib 2.037 or newer
Compress::Raw::Zlib 2.037 or newer
version 0.78 or newer
IO::Compress::Base 2.037 or newer
IO::Compress::Zlib::Constants 2.037 or newer
LWP::Protocol::https 5.805 or newer
Enjoy,
--the VMware team"
Note: None of the Perl modules mentioned as "may be too old" are needed for check_vmware_api to work.
ssax
Dreams In Code
Post by ssax »
What is the full output of these commands as root:
find / -name VIRuntime.pm
find / -name VIRuntime.pm -exec ls -l {} \;
env
su - nagios
env
faizanmalik
Hi Sean,
Please find below:
[root@**NAG-HOST** tmp]# find / -name VIRuntime.pm
find: ‘/proc/820419’: No such file or directory
/root/vmware-vsphere-cli-distrib/lib/VMware/share/VMware/VIRuntime.pm
/usr/lib/vmware-vcli/VMware/share/VMware/VIRuntime.pm
[root@**NAG-HOST** tmp]# find / -name VIRuntime.pm -exec ls -l {} \;
find: ‘/proc/820670’: No such file or directory
-r--r--r-- 1 root root 510 Aug 28 2020 /root/vmware-vsphere-cli-distrib/lib/VMware/share/VMware/VIRuntime.pm
-r--r--r-- 1 root root 510 Nov 23 23:55 /usr/lib/vmware-vcli/VMware/share/VMware/VIRuntime.pm
[root@**NAG-HOST** tmp]# env
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.m4a=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.oga=01;36:*.opus=01;36:*.spx=01;36:*.xspf=01;36:
SSH_CONNECTION=172.36.0.31 59517 172.36.0.152 22
LANG=en_US.UTF-8
HISTCONTROL=ignoredups
DISPLAY=localhost:10.0
HOSTNAME=**NAG-HOST**
OLDPWD=/root
S_COLORS=auto
which_declare=declare -f
XDG_SESSION_ID=28599
USER=root
PWD=/tmp
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
HOME=/root
SSH_CLIENT=172.36.0.31 59517 22
XDG_DATA_DIRS=/root/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share
SSH_TTY=/dev/pts/0
MAIL=/var/spool/mail/root
TERM=xterm
SHELL=/bin/bash
TC_LIB_DIR=/usr/lib64/tc
SHLVL=1
GDK_BACKEND=x11
LOGNAME=root
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-6m5lzJwWCq,guid=3d342b54ccadbb385a273eaf61a5e3a2
XDG_RUNTIME_DIR=/run/user/0
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
HISTSIZE=1000
LESSOPEN=||/usr/bin/lesspipe.sh %s
BASH_FUNC_which%%=() { ( alias;
eval ${which_declare} ) | /usr/bin/which --tty-only --read-alias --read-functions --show-tilde --show-dot "$@"
_=/usr/bin/env
[root@**NAG-HOST** tmp]# su - nagios
[nagios@**NAG-HOST** ~]$ env
LANG=en_US.UTF-8
S_COLORS=auto
USER=nagios
PWD=/home/nagios
HOME=/home/nagios
XDG_DATA_DIRS=/home/nagios/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share
MAIL=/var/spool/mail/nagios
SHELL=/bin/bash
TERM=xterm
SHLVL=1
LOGNAME=nagios
PATH=/home/nagios/.local/bin:/home/nagios/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin
HISTSIZE=1000
_=/usr/bin/env
ssax
Dreams In Code
Post by ssax »
To fix this:
Do this:
mv /usr/bin/six.pyc /usr/bin/six.pyc.bak
Then do this:
ln -sfn /usr/bin/python3 /usr/bin/python
Then run through the guide again to uninstall/reinstall (if it detects it as installed it will uninstall it, then run it again to install it) and send us the entire output again:
Then send the output of this one after doing that:
