XI Trial User: Issue Installing NRPE Agent on RHEL4
bradctl
Post by bradctl »
Attached the nrpe install log.
I know from the RHEL5 nrpe install log that it normally will set up everything and I'll see the services running. Now after an install, I don't see any additions to the firewall, any services running, etc.
Please let me know if you see something that sticks out in the logs.
Thanks.
Re: XI Trial User: Issue Installing NRPE Agent on RHEL4
We have so few people using RHEL4 I think this may have gotten passed over but it appears there is a bug in the installer.
Try to run the following, and then run the fullinstall script again
yum install -y up2date autoconf gcc glibc libmcrypt-devel make openssl-devel perl perl-Net-SMTP-TLS sudo sysstat xinetd
bradctl
Post by bradctl »
This worked, by the way. Thanks.
Thanks for reporting back!
