This support forum board is for support questions relating to
Nagios XI, our flagship commercial network monitoring solution.
DonForigua
Post
by DonForigua »
Hi
Is posiible add a ipaddress to status.dat for example
before
hoststatus {
host_name=XXXXXXXXXXXXXXXX
modified_attributes=0
check_command=check-host-alive!!!!!!!!
now
hoststatus {
IP_address=1.1.1.1
Also for servicestatus
Greetings
benjaminsmith
Post
by benjaminsmith »
Hi Don,
Thanks for contacting us. Let us know the context and I can try to suggest a workaround for you.
Nagios XI does not currently have settings to change the format of this file, so I would have to submit a feature request on this.
Regards,
Benjamin
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
DonForigua
Post
by DonForigua »
Hi dear benjaminsmith
I have a simple cron job for status in csv
For hosts
cat /usr/local/nagios/var/status.dat | egrep -A 33 'hoststatus' | egrep 'host_name|current_state|plugin_output|service_description' | grep -v long_ | sed 's/host_name=//g; s/current_state=//g; s/plugin_output=//g; s/service_description=//g; s/^[[:space:]]*//' | awk '{ printf "%s,", $0 } !(NR%3) { print "" }' | sed 's/,$//g'
For services
cat /usr/local/nagios/var/status.dat | egrep -A 33 'servicestatus' | egrep 'host_name|current_state|plugin_output|service_description' | grep -v long_ | sed 's/host_name=//g; s/current_state=//g; s/plugin_output=//g; s/service_description=//g; s/^[[:space:]]*//' | awk '{ printf "%s,", $0 } !(NR%4) { print "" }' | sed 's/,$//g'
But i would like have the ip address also
DonForigua
Post
by DonForigua »
Or how can i get the status from the host and services from api?
thanks
benjaminsmith
Post
by benjaminsmith »
In the GUI, go to Help > API Docs, and check out the following endpoints,
GET objects/hoststatus
GET objects/servicestatus
You'll find some example commands and you can parse the output on those.
If you'd like to submit a feature request for Nagios Core, the best place to do this is on the GitHub repository. It's an open-source product.
https://github.com/NagiosEnterprises/nagioscore/issues
Let us know if you need anything else.
--Benjamin
Privacy Policy.
DonForigua
Post
by DonForigua »
Thanks for you help
i can maka a report from api + powerbi
