Hi Team,
We need to do a log rotation for directory"/drbd/nagios/var/archives" as the disk is getting filled very often.
Need to know how to do it and will it create any impact or data loss if we do a log rotate on /drbd/nagios/var/archives directory.
Please suggest.
[root@nagios archives]# df -h
/dev/mapper/centos-root 150G 34G 117G 23% /
devtmpfs 16G 0 16G 0% /dev
tmpfs 16G 39M 16G 1% /dev/shm
tmpfs 16G 1.6G 15G 11% /run
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/mapper/mpatha1 1014M 200M 815M 20% /boot
/dev/mapper/centos-var 30G 24G 6.1G 80% /var
/dev/drbd0 188G 127G 62G 68% /drbd
tmpfs 3.2G 0 3.2G 0% /run/user/1003
tmpfs 3.2G 0 3.2G 0% /run/user/1001
tmpfs 3.2G 0 3.2G 0% /run/user/0
You have new mail in /var/spool/mail/root
[root@qy-nagios-a archives]#
Log rotate not working for /drbd/nagios/var/archives
Re: Log rotate not working for /drbd/nagios/var/archives
Hi
/usr/local/nagios/var/nagios.log
The Nagios Core log, includes checks, notifications, external commands, and events. This file is rotated
daily into the /usr/local/nagios/var/archives folder (default setting in nagios.cfg) by rsyslog.
Logs located in the /usr/local/nagios/var/archives folder are used as the data source for the
Availability and SLA reports. Deleting them would cause these reports to show inaccurate data.
https://assets.nagios.com/downloads/nag ... ptions.pdf
What does this show:
It should have one log for each day:
If you do:
you can see if the log rotations is being used:
You could try using an NFS mount for /drbd/nagios/var/archives but if you have issues with the I/O on the
NFS some of the reports may take a very long time to run .
ls -l /drbd/nagios/var/archivesCode: Select all
-rw-r--r-- 1 nagios nagios 3633 Oct 1 23:10 nagios-10-02-2021-00.log
-rw-r--r-- 1 nagios nagios 3633 Oct 2 23:10 nagios-10-03-2021-00.log
-rw-r--r-- 1 nagios nagios 3633 Oct 3 23:10 nagios-10-04-2021-00.log
-rw-r--r-- 1 nagios nagios 6236 Oct 4 23:16 nagios-10-05-2021-00.log
-rw-r--r-- 1 nagios nagios 3633 Oct 5 23:16 nagios-10-06-2021-00.log
-rw-r--r-- 1 nagios nagios 3633 Oct 6 23:16 nagios-10-07-2021-00.logCode: Select all
head nagios-11-17-2021-00.logCode: Select all
[1637038800] LOG ROTATION: DAILY
[1637038800] LOG VERSION: 2.0
[1637038800] CURRENT HOST STATE: 192.168.23.84;UP;HARD;1;OK - 192.168.23.84 rta 5.158ms lost 0%
[1637038800] CURRENT HOST STATE: 192.168.23.87;UP;HARD;1;OK - 192.168.23.87 rta 8.070ms lost 0%You could try using an NFS mount for /drbd/nagios/var/archives but if you have issues with the I/O on the
