How many nodes can be configured using free trial in the first period of 30 days of using Nagios XI?
I've set up 2 switches, and there is a localhost, which is 3 nodes/hosts if I understood correctly. And I can't configure any more nodes, even tho' it says that 7 nodes are included in free trial. It says as follows:
"You have exceeded your license limits. Upgrade Your License or Enter your new license key."
License Type: Free - Purchase a license and receive support and upgrade benefits!
Number of Licensed Hosts: 7
Current Hosts: 3
License Usage: 43%
Trial Options: Enter trial license key
Does it has to do with services that are monitored on the current hosts?
Mostly it's just 24 ports on Cisco Catalyst 2960.
Tnx,
Filip
Nagios XI free trial
Re: Nagios XI free trial
Ok, I just activated free license key, now it works fine.
Was a bit confused because some years ago when I used Nagios XI, it never asked me for free license key.
The topic can be closed.
benjaminsmith
HI @fidia,
Thanks for the update.
Good luck with your trial and let us know if you need any assistance.
--Benjamin
--Benjamin
