Logs stopping and restarting logstash
Every few days all our systems stop sending logs (or so it appears). But, I can get the logs to start up again once I restart logstash (via "service logstash restart"). I assume I shouldn't need to continuously restart logstash. What are some possible causes and what logs on the OS or application can I look at to try and troubleshoot the issue?
Re: Logs stopping and restarting logstash
Hello @tim620
Thanks for reaching out, we see that the logstash.service is running under a init.d script wrapped in java. Here are several places to start looking:
Review the logs for errors, warnings, or other issues related to java and/or logstash.
Please let us know if you want us to either review the System Profile or any logs for issues by sending via private message.
Perry
less /var/log/logstash.logCode: Select all
less /var/log/messages or /var/log/syslog #depending on distroPlease let us know if you want us to either review the System Profile or any logs for issues by sending via private message.
Perry
