installation help please
lucas.shearer
Post by lucas.shearer »
Hi, Im trying to install NagiosXI and running into this issue...
INSTALL: wkhtmltox is being installed...
--2021-12-08 23:34:55-- https://assets.nagios.com/downloads/nag ... x86_64.rpm
Resolving assets.nagios.com (assets.nagios.com)... 45.79.49.120, 2600:3c00::f:92ff:fef7:45ce
Connecting to assets.nagios.com (assets.nagios.com)|45.79.49.120|:443... fail Connection timed out.
Connecting to assets.nagios.com (assets.nagios.com)|2600:3c00::f03c:92ff:fef7ce|:443... failed: Network is unreachable.
ERROR: Subcomponent 'wkhtmltox' installation failed - exiting.
Subcomponents installation failed - exiting
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './A-subcomponents'
This server is on a proxy so I found a topic that directed the issue to here: https://support.nagios.com/kb/article.php?id=147
But in this page it references a /etc/yum.conf file, as well as a /etc/wgetrc file, of which I cant find either.
Also would include the install.log file but cant seem to find that either. Would appreciate any help here. Thanks!
pbroste
Re: installation help please
Post by pbroste »
Hello @lucas.shearer
Thanks for reaching out, understand that you are using a proxy and want to find out which distro are you using?
Here is a link that explains how to use proxy on apt on Debian/Ubuntu:
https://www.serverlab.ca/tutorials/linu ... ntu-18-04/
Plug the proxy configs found from the 'yum' article that you referenced.
Perry
