Collect Data Setup
lucas.shearer
Collect Data Setup
Post by lucas.shearer »
I currently have a running nagiosXI and am trying to simply get it to monitor its own CPU / Usage data. When I run: http://<Myhost>/nagiosxi/api/v1/objects/hoststatus?apikey=<MyAPIKey>&pretty=1 I get 4 records with all sorts of information but when I run: http://<Myhost>/nagiosxi/api/v1/objects/statehistory?apikey=<MyAPIKey>&pretty=1 I get "{
"recordcount": 0,
"stateentry": []
Any idea how to set it up to collect cpu/usage data? so in this statehistory call I can get data of some kind?
ssax
Dreams In Code
Re: Collect Data Setup
Post by ssax »
Does it have to be through the API?
The localhost object should be monitoring those metrics by default if you view the services for it.
You can use Configure > Configuration Wizards > Nagios XI to monitor other metrics as well.
Or you can install NCPA on the system and monitor it with the Linux Server or NCPA wizards.
