Username and password forgotten
Landsadmin
Post by Landsadmin »
I currently purchased the license for the network analyzer but have forgotten my username and password since its been a while a logged in. all the usernames i remember is not working. please i need help
kfanselow
Re: Username and password forgotten
Post by kfanselow »
Hi Landsadmin,
You should be able to reset your nagiosadmin password using the reset script. Simply ssh into the system, su to root or use sudo to run the following:
/usr/local/nagiosna/scripts/reset_nagiosadmin_password.sh -p NEWPASSWORD
After that you should be able to login as nagiosadmin using your new password.
Thanks and Best Regards,
Keith
