nagiosxi plugin to monitor String inside .Txt File
apteancloud
Post by apteancloud »
Hi Team,
We have a requirement on one of our Windows machines to Monitor Text/log files for specific content in the file and give output.
Basically, we will get an output file(consisting of String values Green, Orange and Red) from one of the job scripts in .txt format and we have planned to monitor the file based on it, such that
Green = Ok
Orange = Warning
Red = Critical
Could you guys please suggest which plugin suits the above requirement on Windows machines with NSclient++ agent :)
Thanks in Advance
kfanselow
Re: nagiosxi plugin to monitor String inside .Txt File
Post by kfanselow »
Hi apteancloud,
If you know the strings you are looking for and using NSclient++, writing a VB or powershell script might be the best/easiest route to go. Here's a link to their guide on writing external scripts along with the nagios plugin guidelines:
https://docs.nsclient.org/howto/external_scripts/
https://nagios-plugins.org/doc/guidelines.html
Thanks and Best Regards,
Keith
