I have Nagios XI 5.8.6 installed.
From today at 9:30 am i cant see anymore nothing on dashboard, or service status.
I only can see nodes at notifications. It looks like something is going wrong with the graphical interface.
Can you suggest me something?
Nagios XI not working
Re: Nagios XI not working
Hello @ITNO-SGAL
Thanks for reaching out, and want to start off by taking a look at running services.
You can restart the services by substituting 'status' with 'restart' *(example: systemctl restart nagios)
Please send over the System Profile if you find that the issue persists:
Then send the resulting /usr/local/nagiosxi/var/components/profile.zip file via Private Message.
Perry
systemctl status nagiosCode: Select all
systemctl status httpd #or apache2Code: Select all
systemctl status mysqldPlease send over the System Profile if you find that the issue persists:
rm -rf /usr/local/nagiosxi/var/components/profile.zip
/usr/local/nagiosxi/scripts/components/getprofile.sh SUPPORTThanks,
Perry
Hello again,
All the 3 services are running, i made a restart of them and it is the same thing.
#systemctl status nagios
● nagios.service - Nagios Core 4.4.6
Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2021-12-13 16:38:08 CET; 19h ago
# systemctl status httpd
● httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/httpd.service.d
└─php-fpm.conf
Active: active (running) since Mon 2021-12-13 16:36:29 CET; 19h ago
# systemctl status mysqld
● mysqld.service - MySQL 8.0 database server
Loaded: loaded (/usr/lib/systemd/system/mysqld.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2021-12-13 16:36:31 CET; 19h ago
Then i have run these commands
and
The profile.zip is now generated, i am sending you in private message.
Thnx!
└─php-fpm.conf
and
Thnx!
Hello @ITNO-SGAL
Thanks for sending over the System Profile, after review we see that on Sun Nov 21 around 08:25:46 things are unable to connect or resolve the host (localhost, hostname). Two examples:
Perry
httpd: Could not reliably determine the server's fully qualified domain name....
Following to check:ndo_handle_host_status(ndo-handlers.c:1036): Unable to bind parameters
- System /var/log/.. Logs
- /etc/hosts file
- Apache configuration updates
- proxy config's
- SELinux Policy
- Firewall Rules
- IPTABLES Rules
- httpd Service Status restart
Perry
