740 in /var/lib/shellinabox
efxSPN
Post by efxSPN »
Would there be any problem to put 740 instead of 744 to /var/lib/shellinabox?
Kind Regards
kfanselow
Re: 740 in /var/lib/shellinabox
Post by kfanselow »
Hi efxSPN,
That should be a problem and you can always revert back if it does cause problems. Looking at my own instance it appears that it is set 750.
37605141 0 drwxr-x--- 2 shellinabox shellinabox 62 Sep 16 15:09 /var/lib/shellinabox/
Thanks and Best Regards,
Keith
