High Availability
High Availability
I've read the PDF on Nagios XI HA located here: https://assets.nagios.com/downloads/nag ... ios-XI.pdf which discusses using the VMWare high availability option. We're moving our XI server into Azure and from the sounds of it the best bet will be to just use the Azure HA options like zone redundancy to achieve an HA environment for NagiosXI. Before moving forward with that though I just wanted to confirm here first if Nagios XI has any recommendations or best practice for a HA setup in Azure?
Re: High Availability
HI,
Thanks for reaching out. Unfortunately we have not mocked up and tested an HA Nagios XI
implementation on Azure as our current efforts are focused on completing and testing
Nagios XI 6.0. You may want to check with Microsoft regarding best practices for HA of
Linux-based systems. You could also search https://support.nagios.com/forum/ to see if any
community members have any experience or recommendations.
Gotcha. In that case I'll follow through with the Azure best practices. Thank you for the response!
Sounds good.
Good luck!
Sounds good.
Good luck!
