Bulk Mod Notifications
uinthas
Post by uinthas »
I recently set up several new hosts and services. Would appear the default notification contact is nagiosadmin. I need to change that to a group (already created)but don't want to go through each host and service to set this. I looked at the bulk mod and don't see an option for this, how would I accomplish this?
kfanselow
Re: Bulk Mod Notifications
Post by kfanselow »
Hi uinthas,
In the bulk modification tool you should be able to add a contact group then remove the nagiosadmin user using remove contact button. I'll attach a screenshot with the options underlined for convenience.
Thanks and Best Regards,
Keith
