Hi ,
We are getting the subject line error message on of the service check although when checked, found out that was false alert. Can you please help to troubleshoot this issue.
Below are the service check definition and check command definition.
service_description WMSEW: Web Interface
use wms-service-template
check_command check_pkmsweb_login!"http:abcd"!"NAGIOS"!"1901"
host_name hostname
_resolver_group Warehouse Management Systems
servicegroups +app-wms-gk
notification_interval 15
command_name check_pkmsweb_login
command_line $USER1$/ce/check_pkmsweb_login $ARG1$ $ARG2$ $ARG3$
Please help us to troubleshoot this
Return code of 255 for service 'WMSQL: Web Interface' on hos
rahul2gupta
