User not receiving email notifications
pavan509
Post by pavan509 »
Hello Team,
I have created 3 new users on the Nagios platform with AD authentication enabled. Out of 3 users, 1 user is not receiving both host and serviceemail notifications. So I have reconfigured the user and also readded the user multiple times but no result. I have enabled the notifications at host and service level from CCM panel as mentioned below.
Configure --> Core Config Manager --> Contact Groups --> Contact group name --> Manage Contacts --> select the contact to be added --> Add Selected --> Close --> Apply Configuration.
I can also see that notifications are getting triggered from the Nagios to that user from event logs. Attached the screenshot of the same for reference.
Let me know how can I troubleshoot this issue further.
Thanks, Pavan
benjaminsmith
Re: User not receiving email notifications
Post by benjaminsmith »
Hi Pavan,
Make sure they check their spam folder.
Then, I would check the mail logs for any errors. First, make sure you have PHPmailer logging enabled on the system.
There are user preferences for notifications as well, but if the notification handlers are getting triggered for the contact, then it's likely an email issue.
If you find any errors in the log, please post them to the thread for us to review.
Benjamin
pavan509
Post by pavan509 »
Hello Benjamin,
I have verified the user's mailbox and no emails were received either to the inbox or to the spam folder. I verified the outlook rules as well to confirm that they are not being redirected to any folder or being deleted by default. PHP mailer logging is already enabled and I couldn't see any errors in the logs. I can also see notifications are being triggered in the Notifications log. The user is also receiving emails for the scheduled reports and a 2FA code for the login.
Any further advice to investigate the issue and fix is highly appreciated.
Thanks, Pavan
gsmith
Post by gsmith »
Hi
In the screenshot you posted it looks like this command is failing:
nagios_send_service_mail.pl -p "Schneider-Electric" -r "[email protected]" -f multi -u -l en
You could try running that from the command line to see if you can determine the error, maybe there is a -v (verbose) option?
nagios_send_service_mail.pl is provided by a third-party, you should contact that third-party for support.
pavan509
Post by pavan509 »
I tried adding the user in my test environment and enabled notifications of test devices. It worked fine without any hiccups. So, what I understood is that the nagios_send_service_mail.pl plugin is the culprit as it is not supporting the SMTP authentication-based email generation. Can someone guide me on how to remove the emails getting generated through the plugin and configure it to the default method?
Thanks, Pavan
gsmith
Post by gsmith »
Hi
To use the default method, go to Admin, Email settings and configure your system like:
You'll need to change the email addresses, and the server, port, protocol to your requirements.
To stop using the plugin uninstall it by reversing the installation instructions found at:
https://nagios.fm4dd.com/howto/manual/n ... _mail.shtm
Note: there may be uninstallation instructions in one of the authors documentation pages.
pavan509
Post by pavan509 »
Hi Team,
I had revoked the existing notifications and replaced them with the default settings. Now, a new problem arises, all the users are not receiving the host-related notifications. No issues were observed with the service-related notifications. Can someone guide me to fix this issue?
Thanks, Pavan
gsmith
Post by gsmith »
Please send me a System Profile so I can take a look.
1. Login to the Nagios XI GUI using a web browser.
2. Click the "Admin" > "System Config" > "System Profile" menu pick
3. Click the "Download Profile" button
4. Save the profile.zip file and share the file in a private message and then reply to this post to bring it up in the queue.
pavan509
Post by pavan509 »
Hello Smith,
I have sent you the System profile in PM. Please check and let me know for further actions.
Thanks, Pavan
gsmith
Post by gsmith »
I loaded your System Profile and took a look at some Host and Service configurations.
Looking at your host GB-WORTHING for example, there are not enough settings to perform checks or notifications:
You'll need to assign values so that checks are performed and notifications can be sent.
Please let me know if there are issues after adding the values.
