I am trying to monitor Oracle instances using Nagios and the same error code keeps on returning.
I have re-ran the commands however the same output is displayed. On the troubleshooting guide it states to use the check_foo command which isn't present on the remote server.
I would've thought that this would be a default command as we have upgraded our Nagios instance, however is this not the case?
Thank you in advance.
Return Code 127 out of bounds
Re: Return Code 127 out of bounds
Hello @Chris Watson
Thanks for reaching out, typically when we see a 'Return Code 127' indicates that the plugin may be missing. Please review the following article:
https://support.nagios.com/kb/article/nrpe-return-code-of-127-is-out-of-bounds-plugin-may-be-missing-613.html
Please let us know how things look,
Perry
Perry
