Hi
is it possible to change the SNMP trap service name? I tried selecting the service, configure tab and then re-configure service and the service name is greyd out.
Also for some traps the messages contain loads of lines and some contain for example enterprises.20246.2.3.1.1.1.2.2.17.0 ():2 enterprises.20246.2.3.1.1.1.2.2.18.0 lines. Does that mean that the MIB is not corretly proccessed? The message shouldnt contain oid's or should they? I checked the corresponding MIBs (manage MIBS) and also clicked Proccess Traps for those but the message still contain OID's.
Thank You!
snmp trap service name and trap message
Re: snmp trap service name and trap message
Please run this command as root and PM me the resulting /tmp/SNMPFILES.tar.gz file:
GZIP=-9 tar czvf /tmp/SNMPFILES.tar.gz /etc/snmp /usr/share/snmp/mibsGenerally, yes. Please send me a screenshot of the full message.Also for some traps the messages contain loads of lines and some contain for example enterprises.20246.2.3.1.1.1.2.2.17.0 ():2 enterprises.20246.2.3.1.1.1.2.2.18.0 lines. Does that mean that the MIB is not corretly proccessed?
Sent them, can you have a look please?
It looks like it's not expanding them properly even though you have this set in your /etc/snmp/snmptt.ini file:
Please run this command:
Then generate one of those traps and then send me the trap file for the trap from this directory so I can lab it up:
Once you've grabbed it, start snmptt back up:
# Configures how OIDs contained in the VALUE of the variable bindings are handled.
# This only applies to the values for $n, $+n, $-n, $vn, $+*, $-*. For substitutions
# that include variable NAMES ($+n etc), only the variable VALUE is affected.
# Set to 0 to disable translating OID values to text (symbolic form)
# Set to 1 to translate OID values to short text (symbolic form) (eg: BuildingAlarm)
# Set to 2 to translate OID values to short text with module name (eg: UPS-MIB::BuildingAlarm)
# Set to 3 to translate OID values to long text (eg: iso...upsAlarm.BuildingAlarm)
# Set to 4 to translate OID values to long text with module name (eg:
# UPS-MIB::iso...upsAlarm.BuildingAlarm)
# For example, if the value contained: 'A UPS Alarm (.1.3.6.1.4.1.534.1.7.12) has cleared.',
# it could be translated to: 'A UPS Alarm (UPS-MIB::BuildingAlarm) has cleared.'
# Note: net_snmp_perl_enable *must* be enabled
translate_value_oids = 1Code: Select all
systemctl stop snmpttCode: Select all
/var/spool/snmptt/Code: Select all
systemctl start snmptt
