Nagios shows server is down - but its UP.
sysmate
Post by sysmate »
I've added a new server to be monitored by my Nagios Server,
It successfully connected to the remote Server, I've set the parameters and values which I want to monitor,
But after I save the Config, Nagios will show me that the Remote Server is DOWN (although it's UP and running),
BUT Nagios will keep showing the me values of the Parameters which I've set to be monitored on the Remote Server (Disk space, CPU etc.)
How can that be?
How can it be fixed?
Please help!
Dor
pbroste
Re: Nagios shows server is down - but its UP.
Post by pbroste »
Hello @sysmate
Thanks for reaching out, let's have you run through this:
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
Restart the services by bouncing:
systemctl restart nagios
Let us know how things look.
Perry
ssax
Dreams In Code
Post by ssax »
Does it show properly in the Nagios Core backend? Go here on your XI server, login with your XI credentials, and see what the host state is there:
http://YOURXISERVER/nagios/
Please PM me a copy of your profile.zip, you can download it from Admin > System Profile by clicking the Download Profile button.
- NOTE: The profile contains sensitive data so don't post it here, send it through Private Message OR create a ticket at and send it through there
